Configures the LLDP port to advertise or not advertise port vlan ID information to its neighbors. This allows a VLAN bridge port to advertise the port VLAN identifier that is associated with untagged or priority-tagged frames.
all | Specifies all ports on the switch. |
port_list | Specifies one or more ports or slots and ports. |
advertise | Specifies to send the information to neighbors. |
no-advertise | Specifies not to send the information to neighbors. |
No advertise.
The port VLAN ID TLV allows the port to transmit the VLAN ID associated with untagged VLANs. There can be only one port VLAN ID in each LLPDU.
If no untagged VLANs are configured on the specified port, the TLV is not added to the LLPDU, even if you configured this to advertise.
The following command configures all ports to advertise port vlan ID information to neighbors:
configure lldp ports all advertise vendor-specific dot1 port-vlan-ID
